Somalia757 SOMALIA Feb 29, 2008 #1 This being an older cable tranny from japan what clutch do I ask for when I go to order my clutch kit? Also will my 93 ls flywheel fit on it?
J jeffsciv23 Senior Member Mar 3, 2008 #2 i am pretty sure that all cable b series trannys have the same amount of splines on the shaft.
92civicb18b1 The Trisexual Mar 3, 2008 #3 yes, I'm pretty sure the spline will fit. BTW, you're flywheel mounts to the motor, clutch to flywheel, transmission to motor.
