What do I need to do to my stock motor to put stage 3 cams in it
Discussion in 'Integra' started by 91db1ls, Sep 11, 2015.
  1. 91db1ls
    91db1ls New Member
    I have a b18a1 motor that's completely stock with higher miles around 200xxx. My question is what all do I need to do to my motor before I can put them in. I have a healthy transmission I just put in a new clutch kit with a lightened flywheel the head was ported and polished.
  2. get_nick
    Washington State
    Why do you want stage 3 cams?
  3. Briansol
    Cams should match your compression.
    If you aren't going to a high comp. piston, running a stage 3 cam won't net you much gain, and in fact, may make you slower.
    If you don't want to tear apart the block, stage 1 is about as big as you want to go. TO support those, you'll need upgrade valve springs and retainers.
  4. 91db1ls
    91db1ls New Member
    I got the cams for a killer deal I'm only into them 60 bucks there Brian crower stage 3 cams they've never been used so I just thought I'd get them the worst case is I'll trade them or resell them. There about $450-500 new so I couldn't pass it up
  5. Briansol
    yeah that's a good deal...
    maybe try to trade them out with someone going BIG, or go BIG yourself with a high compression rebuild :)
  6. get_nick
    Washington State
    Honestly, you would spend more money building the engine for those cams than if you sold them and put the money towards a budget turbo build. The turbo will also yield better power.
