What Ecu Do I Need?
itsbigmike
I got a 93 civic and putting a b18a from a 91 ls in this weekend, pretty sure I need the p75 ecu from a 94-95 ls 5spd, just want to make sure before I buy it
bad idea
the engine you are trying to use is OBD-0
your car is OBD-1
the ECU you are trying to use is OBD-1
the ECU is going to look for a lot of sensors and shit that the engine doesnt have ... so its going to be a bitch to get it running right
that engine also comes with a cable tranny your car has a hydro tranny
it is also illegal in most places to put an engine in the car that is older than the car
i would rethink your choice of engine
I believe that hasport sells teh correct tranny mount for the cable tranny's and you will also need to get a CRX pedal box, and the cable for that 91 ls tranny. Not sure on ecu. I believe that we have a ecu guide under the reference page.
Milan
Heh, put it this way, I have the engine tranny, mounts, brackets, cable conversion, engine harness, etc, everything except the computer, I'm gonna make it work, just gotta get the right ecu
