What fuel does JDM b16a SiR II uses?
Discussion in 'HYBRID -> EG-EK / DC' started by Akirazian, Dec 30, 2002.
  1. Akirazian
    Akirazian Banned
    What fuel does the JDM B16a SiR II motor uses? Well, in my state (California). The highest octane gas that i've seen is 92. But i'm using 91. Am i using the right gas? It makes ticking noises. And I was wondering if i am using the right fuel. I have the basic mods I/H/E
  2. micah
    micah Senior Member
    panama city beach, florida
    just get the highest gas possible, if i dont put premium in my usdm b16 it ticks...highest here in fl is 92
  3. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    get some octane boost, im pretty sure that the jdm motors have been run at a higher octane then we run here. you might want a vavle job done also if you dont already have one done.
  4. GSRCRXsi
    MD
    micha- it ticks if you dont put premium in ur USDM b16? i dunno bout u but i run regular ol' 87 in my GSR engine and it runs fine.
  5. micah
    micah Senior Member
    yeah my motor ticks with anything below premium...
    b16a3 in a 94 sol
    when i bought it the guy told me that and i thought it was crap, i mean i was planning on running premium anyway but whatever, anyway my dad put cheap gas in it once and it started ticking
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    well, the b16 does have a higher CR than the b18c (gsr) i dont put anything but premium in my car either, you want to avoid knocking/pinging... guess it matters how much you care about your motor :)
  7. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Japan has 98 octane gas so yes your correct there. octane boost does nothing. It raises octane levels by like .1 points, it is not worth the money
  8. pissedoffsol
    really, just use 91 pr 92, and get a valve adjustment so your ticking stops :p
  9. asmallsol
    i know that this is pretty much totally non related but what is the octane rating for Diesel Fuel? Is it possible to ignite (sp) with a spark plug at higher compressions (like over 15:1 cp ratios)?
  10. phunky.buddha
    Dallas / Fort Worth, TX
    I don't know the octane rating for diesel fuel, but I'm sure that there is one. I don't see why you couldn't ignite it with a spark plug- you wouldn't need high compression to fire it with a spark either.
  11. SixtySecondAssassin
    Austin, TX
    diesel will prolly dentonate before tdc with that high of a c/r.
  12. B16
    yay area, CA
    for sure, it relies on detonation to run :D
