What Gauge wire
Discussion in 'ECU's, Electronics, and Tuning' started by asmallsol, Dec 2, 2003.
  1. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    This weekend is when I am going to be doing the swap. I have bought just about everything that I need for the swap, including fluids, belts, clutch (already installed) ect. Last thing that I need is the wire for the swap. Do I even need it, and what gauge.
    The number that comes off the top of my head is 8 gauge wire, but I could be wrong.
    (for those who dont know, I am swaping in a 95 GSR into a 95 sol, using the Sol harness and the GSR p72 ECU)
  2. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    wiring for what? battery, solenoids, sensors?
    for sensors/solenoids i think you can use 16 gauge. 8 would be OVERKILL.
    for battery, and grounds probably 8 guage. good luck!
    EDIT: the smaller the gauge # the bigger the wire. vise versa
    edit # 2 wow i have over a thousand post...
  3. MaliWho97
    MaliWho97 Senior Member
    8 gauge is way too big... If you are wanting stock sized wire, you will want to use 14-16 gauge.
  4. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Why are you using a del Sol harness on a GSR engine?
    Just get yourself a GSR engine harness, add the IAB & Knock sensor wires, call it a day.
    I used 18 gauge wire for my add-ons.
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i used my del sol harness on my b series swaps and only had to extend the o2 sensor wires, since i ran hondata/p28 and it didn't look for the knock
  6. asmallsol
    Adam, I would Like to run the knock sensor just for security reasons. I also have to do some wiring for the IAB. If I had more money, I would just buy a skunk2 manifold but...maybe later.
    Where did you end up putting the O2 sensor? The normal d series location (middle of header/manifold) or did you do the b series location of right at the CAT?
  7. pissedoffsol
    i used my z6 harness... and everything reaches except the oil presser sender. since i have an aftermarket guage, im probably not going to plug it in at all... waste of time for an idiot light.
    and all i have to say is fuck knock sensors.
    i can, however, see your point for wanting the iab hooked up.
    o2, put it by the cat- it gets a better reading there
    so, you really shouldn't need any wire :)
  8. pills_PMD
    New Albany, OH
    word on the FUCK knock sensors...
    you will have to extend the O2 sensor wires though...
