what head should i use?
Discussion in 'Engine Building' started by je power, Mar 30, 2010.
  1. je power
    je power New Member
    my house
    im doin a vitara build. im usin a z6 block and crank with tuner toy rods. i want the highier compression so i was thinking about usin the y8 head because of the smaller chambers. but the z6 head flows better at higher rpm. if someone can help me on choosin a head that would be awesome thanks
  2. tabKola
    tabKola New Member
    Tewksbury MA
    Well, what are your goals for the build and what are you going to be using it for?
  3. 34diesel34
    34diesel34 Import Tuner
    USA
    The z6 head would be best. 1. it's the head that's supposed to be on your block 2. you wont have to worry about timing issues and headaches.
  4. je power
    je power New Member
    my house
    im only going for around 350hp. i guess i could just get away with shaving the head for the compression. thanks for the input guys
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    FJT sells the "correct" rods that'll bring the compression back up with Vitara pistons. Milling the head is pretty common for the non-Y8 D-series; some people even milled their Z6 heads until the point it has quench pads too(about 2.5mm off the head IIRC). The milling actually de-shrouds the valves and helps flow a bit more. :)
  6. je power
    je power New Member
    my house
    I will measure my rods when I get home tonight. I was only gunna shave the head .005 and the block the same. Im having my head ported and polished so im not to worried about flow.
