What Is N Lsd
jawdropr
Banned
does anyone know what an lsd is when you want to buy a new motor?
when i buy a new motor should i buy one. i want to buy either the b16a sir2 or the b18b? im new here bt ifi go with turbo im gunna buy the b18b if not just the b16asir2
lsd= limited slip differential, it's a device that doles out equal amounts of power to both of the front wheels, which helps to eliminate the problem with cars that don't have it. From a launch, a car without lsd will have one front wheel with no power going to it, and the other has all the power, this causes that tire to lose grip so relatively little power is mkaking it to the pavement, also the car will tend to torque steer(on side of car is being pulled more than the other cause the car to act like it wants to turn) under heavy acceleration. an LSD will put equal amounts of power to the pavement through both tires, allow both tires to accelerate at the same time eliminates torque steer, and it also allows relatively more power to be transfered.
In short, with two similarly odified and tuned engines in the same model/trim level car, and similar driver skill, the one with LSD will be quicker off the line.
ahh thank you s much i was cofused, its a 93 civic hatch, i have to buy a motor and tranny but i want to kow what the best i to work with in my car, i wanna get a turbo so i should get the b18b right? and what other mods should i d also to make it insane, lottacompetition out here, i live in queens and veryoneas something quicker and nicer, i just wanna sleep on eveyone, let me know the info
