What Is The Absolute Best Engine For A 92 Civic Si
Discussion in 'HYBRID -> EG-EK / DC' started by AraCerE, Mar 11, 2003.
  1. AraCerE
    AraCerE Junior Member
    I am new to the import car scene and I am about to buy a 92 Civic Si-R....It already has a DOHC VTEC engine in it.........I was wondering what would be the absloute best motor that I can put in it and money is no abject.
    Thanks,
    A ra C er E
  2. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    What motor is in it now? The best is just your own opinion. But H22 is the most powerful.
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    a well built b20 w/ a turbo would waste an h22
  4. SFPracing
    SFPracing Senior Member
    Miami, Florida
    Best stock motor would probably be B20Vtec. Best motor would be a B1c5 Type R with sleeved bottom end, forged internals, and ported head with all the stronger internalss.
  5. TRuggiero_
    Winter Garbage, Fl
    He said whats the best motor, of course I could build a better motor, but H22 is the best motor platform, you can't argue. The best built motor would be CRVTEC/T with a Type R head. And there is no B20VTEC stock motor, it's a hybrid motor.
  6. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    I must agree with some of the guys and say the B18C1 is probably the best stock motor for all around performance to throw in there but you are restricted a little. What I mean is that the R-spec motors are already pretty well designed and put together and you probably won't be able to get too much more out of it.
    However, I believe the biggest bang for the buck is the H22 but there is a small weight issue(a cf hood and battery relocation should fix), and you have to beef up your suspension a bit. Still worth getting but don't expect to be Michael Andretti with an H22.
    -Why are you trying to swap out the engine??? You already have a Dual cam Vtec motor, save the money you will spend on a new motor and just build on it or slap a turbo on it.
  7. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Same thing I was thinking. Just build up your existing engine. If you want to stay NA but still want trq. buy a ITR bottom end on that head. You already have a sweet engine and there is no reason to swap it out.
