Well what motor did you put in, or did you just do a mini-me swap. If you put in a DOHC ZC then a PG7 or a PM7 is best. If you just put an si head on your block then a PM6 will probably do just fine for you. D16Z6 uses a diff ecu, but I forget which one, look it up if you need to know.
