what is the best Ls Vtec for my build?
Discussion in 'Engine Building' started by daGSRhatchNEPA, Aug 31, 2009.
  1. daGSRhatchNEPA
    daGSRhatchNEPA I love my Honda
    allentown
    im trying to get around the high 200hp range. Working with a b20 Ls vtec and a Gsr head... i also wanted to add in a jackson racing supercharger... i need help with compression ratios cuz i have seen pistons stuck inside of blocks b4 with the improper sizing like 14.5.1 yeah idiots. so i am thinking maybe 12:2:1?? for a mid range compression supercharged car with 10-12 psi? sound good or am i out of my mind.. also injector sizing i will need as well. i am thinking toda stage 2 cams as well. the rest is a cake walk or is it??
  2. hooligan
    hooligan New Member
    ATL
    Yes, your setup is crazy! If you just want to make 200 hp forget about the supercharger. GO to ENDYN - www.theoldone.com , they make 300 hp NA b20's. Go to the their " Articles" page and they have pages of how to build a 300hp B20 vtec! some reputation points would be nice:)
  3. daGSRhatchNEPA
    allentown
    yea
    i know about him from hondatuner mag..
    would have been nice if you could send me to the exact article ;)
    then points!
    btw they took my rep power away :(
  4. hooligan
    hooligan New Member
    ATL
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you are on crack if you think your running high compression pistons and a SC.first the compression will be far too much when boosting..and the b20 sleeves are real weak..
  6. daGSRhatchNEPA
    allentown
    compression
    if 12:2:1 is too high to run a supercharger. what would be an optimal compression ratio?
  7. hooligan
    hooligan New Member
    ATL
    NOthing over 10:1 would be O.K. (9:1 would be safer) thats why the b18b with (8.5:1 i think) is the optimal stock motor for boost.
    High CR + boost = blown motor
    12:2:1 is what CR you want with a NA motor
    Anyways B20 stock blocks arn't worth a crap for big hp, like ENJYN78 said..
    ENDYN uses Dart block for their builds.
  8. E_SolSi
    there are plenty of people boosting high compression engines... and doing it reliably
    its all in the tuning
    ENDYN, and specifically Larry Widmer is a hack ass bullshit artist that i wouldnt trust to rebuild my fucking lawn mower... i know plenty of people who have blown the hell up due to their shitty parts and or tuning
  9. hooligan
    hooligan New Member
    ATL
    Your just hatin on me. Please tell me of a B20 street car running 12:1 compression and at least 10 pound of boost on pump gas.
    Yes there are some racers doing that but their engines last at the most of 1/2 a year and they use Dart blocks
  10. BrutalB83
    Rochester Hills, MI
    Wow OP, you're really popular around here, aren't you?
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    lmao i jus realized this is the same guy that wanted to beat my ass awhile back for telling him his answer was incorrect..he threatened B as well
  12. hooligan
    hooligan New Member
    ATL
    Haters want to make me sound bad when everybody else is doing the trash talking,
    I schooled yall on camber,caster, toe, when one of yall were cusing at me and said only toe wears on tires( camber does to smarty)
    Then i could not seem to explain somebody backspace and offset and somebody called me out saying hondas dont have around +40mm offset and said that i had it backwards.(backspace is were the mounting surface is compared to inside edge of the wheel) ( offset is the difference of the center of the wheel compared to backspace/ the mounting surface.)
    ( hondas have around 40+mm offset) check it out at tirerack.com and American Racing wheels explains it completely
    ( It makes me laugh when you cuss at such simple things)
    Then i just schooled a hater calling me out saying boosting high CR motors with boost is smart! haha
    detonation dummy (you have to run race fuel to pull that crap off)( and be ready to build a new engine every 1/2 a year or so depending on how much you run it.
    yall make me laugh
  13. hooligan
    hooligan New Member
    ATL
    Please explain if any of what I said above is incorrect with reliable information without cussing.
    IF yall can do that then you will have my respect.
    The next person that calls me out apperently does not know what they are talking about
  14. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    go answer my question i left for you on the camber issue, and i have friends with high comp motors that are turbo putting down 700+ and they drive the car almost everyday
  15. hooligan
    hooligan New Member
    ATL
    havn't got your guestion in my inbox? What i was trying to explain about camber is if it changed it will wear the inside if you try to tuck the tire in. MY friend did a lift on his truck with new tires without getting an alignment and his tires lasted a month b/c the camber change weared on the outside of the tires. Any change in camber (other than alignment) will wear tires out quicker. so it would not be a good idea to tuck the wheels by changing
    camber. that much camber would hurt handling also b/c the weight of the car would mostly be on the inside of the tire.
    It would work but you would be changing out tires alot more often and handling would be diminished.
    Did that explain my reasoning?
    Need more info about your friends car to be reliable info, like i said in my last post.
    What motor, CR, how much boost, what type of fuel, etc.
  16. hooligan
    hooligan New Member
    ATL
    thanks for trying to understand what i have to say
    I guess it would have been a good idea to say i worked in a tire shop for about a year. oops:)
  17. E_SolSi
    hater???
    what is this "hater" you keep speaking of??
    and i never said that boosting on a high compression engine is smart... i also never said it was dumb... i said that it can and has been done, and that it requires precise tuning
    i did say that ENDYN (and specifically Larry) are hacks that make garbage parts, and tune like crap and are responsible for blowing up more than a few cars.
    i do not want nor do i care about respect from you, so let me drop an F bomb right now just to make sure that is taken care of.... FUCK!!!
    you schooled no one on camber caster and toe... you posted an informational video that did nothing more than explain the basic concepts of the three... you did not make the video, you simply linked to it... it still had nothing to do with the conversation at hand at the time...
    toe IS responsible for the bulk of tire wear... camber can contribute a small amount over time, and if you dont like to take corners at any rates that would scare a grandmother, but the camber would need to be off by a ridiculous amount for it to cause excessive tire wear... and by that time other things, like suspension geometry, would be far greater of a concern than tire wear...
    you are the worst kind of idiot... you are an idiot who knows how to go out and find little nuggets of information, nuggets that you like to pass off as knowledge... but you dont have any knowledge, and you dont have any experience... all you have is these little nuggets... and you try to pass them out to impress people... much like a thug who tries to use large words to sound intelligent, but they dont use them or even pronounce them correctly, so they expose themselves as even bigger idiots...
    how long have you been tuning cars? i mean really tuning them... not just replacing worn equipment, not putting things back to the factory specs, and not simply taking directions from someone else...
    how many track cars have you built?
    how many times have you actually played around with changing and tuning things like camber, caster, and toe, to see how it actually effects the handling characteristics of a vehicle?
    how many times have you sat down and figured out the best practical suspension geometry for a vehicle, for the specific track or type of driving you would be doing, not based off of how many inches lower than stock you would be, or how much wheel gap you would have, but truly figured out, based on driving style, handling needs, and surface conditions, the ideal settings?
    how many times have you manually figured out and performed a vehicle alignment? how any times without the use of a computerized alignment machine?
    how many times have you corner balanced a vehicle?
  18. E_SolSi
    and the truth comes out... you are the exact type of idiot i thought you were
  19. E_SolSi
    you reported me for language on that post???
    exactly what part of that post was inappropriate language??
    "idiot"??? im sorry i thought that was pretty G rated
    hell at least in the post above that i said "FUCK"
    you really are a fucking moron
    feel free to report me again for this post you dumb mother fucker, of course im a moderator, so youre really only reporting me to myself :shrug:
    have a nice day you fucking ass clown shit bag... go fuck yourself :fuckyou3:
    1 person likes this.
  20. hooligan
    hooligan New Member
    ATL
    Yes i did school eg6sir who said that camber cannot wear out tires and whoever else
    You talk a big talk in your 1 page post but i dont see any credentials of yours. pics, anything!
    You just waisted writing a page b/c your pissed off at me. funny
