Originally posted by CRX-YEM@Nov 2 2004, 09:02 AM
A really good explination of camshaft specifications
Duration effects engine idle, a high duration cam will have a very rough idle and low vacuum. Have you ever heard an old muscle car that sounds as if you can hear every cylinder fire that's due to a very larger duration cam.
changing the lift and duration change the area under the curve.
A high lift short duration has a narow band
typical for trying to produce more hp
were a lower lift long duration has a wide band
typically produces more torque
[post=410532]Quoted post[/post]
