What next?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by leonc, Jul 21, 2005.
  1. leonc
    leonc Senior Member
    Las Cruces
    I am in the stage of doing my suspension (also tuning my motor). I have illuminas with ground controls (love it). What else can I do to help the car handle better especially when cornering at higher speeds. I want to get involved in autcross.
    Leon
  2. E_SolSi
    sway bars
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    :werd:
  4. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Not to thread jack, sort of but on topic, what are some good brands to buy for sway bars? Eibach? Also do strut bars help at all? And What about brands for those?
  5. asmallsol
    depends on what your looking at and your suspension setup. Honda offers tons of OEM bars from like 13mm or so all the way to 23mm. A 22mm ITR rear swaybar is bigger then almost all other aftermarket brands.
  6. leonc
    leonc Senior Member
    Las Cruces
    Will an itr front and rear fit on a 94 civic ex?
  7. asmallsol
    If you have a factory rear swaybar, then yes. If not, your going to have to buy new rear LCA's to accept swaybar endlinks. You will also have to buy the proper bushings and d-brackets. Also, for a rear swaybar, it is almost manditory that you buy a mounting/reinforcement kit like the beaks, BSQ, or ASR (asr is by far the best and most complete kit, however, its really expensive)
  8. micah
    micah Senior Member
    panama city beach, florida
    new bushings all around will help ;)
  9. drumballer
    drumballer Junior Member
    st louis
  10. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yea, that's really going to boost performance in his Civic <_<
    Sway bars, new bushings. New bushings may seem like something small that won't do a whole lot, but let em tell you, it can completely revive a cars feel.
