thank god you told him the right answer befor some noob told him 50psi or somthing dumb. I spray high build at around 13-15 psi but i am runnning a 1/2 airline on a big tank so i flow more air at a lower psi.
yip i run very low for primer as well such as around 15 psi. For basecoat i run abot 19 psi and about 17 to dust coat the last coat if it is metallic. clear i run at around 21 to 23 psi
