What Should I Drop In My Crx?
Discussion in 'HYBRID -> EG-EK / DC' started by 88crxdx, Mar 5, 2003.
  1. 88crxdx
    88crxdx Member
    what i want to know is what is the best setup for my crx? i plan to turbo the engine. i want to drag race only but still want to be able to turn. i say this because the h22 would be very hard to turn would'nt it? also i was thinking about the s2000 engine. well i just want ideas and your idea of making a drag car out of a crx, but not too extreeme where i need to have a whole front end confersion. what would be the best setup in it, b-series to whatever, let me know thanks.
    p.s. i dont just want to know the best value of the swap, i want to know the fastest and the most potential for it.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Well stop thinking about the S2k motor,unless you just sold a couple kilos and have money to burn.It's RWD,not easy for anyone to put in a FWD car.Anyway get a GSR and boost it,tune it.
  3. 88crxdx
    88crxdx Member
    o shit my bad i fuckin forgot the s2000 was rear wheel drive, but would it be possible to have it awd?? but its just a ?? so a b18c would be the best??
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    awd, 4wd, rwd 4x4ing, just does not work in a civic.
    Best? how much you want to spend, what your goals are ect.
    A b16 is the best for the price,
    b18a cheap no thrills engine, good for turbo,
    b18c is expensive and challenging for the rex but it will be pretty fast,
    h22, very fast strait lining, not the best handlin
    any of these can be turboed but this will cost money.
  5. xj0hnx
    C.C.TX.
    IMO from what I have read here and other places,the GSR B18C1 offers the best boostable power all around.With proper tuning it can be pretty well boosted,and remain reliable.As far as AWD,same as the s2k,way to much work and money for nothing.
  6. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    B18C1 - it's the best motor for your chasis if you were going to run it on the street.
    Because you want to drag race only I would say go with the biggest monster you can find that will fit in your car, let's have the votes:
    I vote for H22.
  7. ekPhred
    ekPhred Senior Member
    i agree, you said in the beginning of the thread that you want to go drag, so i would opt for the h22a, for the street, i would recommend a b18c, that would be awesome on a rex on the street. good luck.
  8. xj0hnx
    C.C.TX.
    I'll say it again B18C1.Not to mention your talking about a CRX,which is going to pose it's own special set of problems with a H22 along with handling.
  9. Spyderturbo
    Spyderturbo Senior Member
    PA
    If swap value is of no concern I assume your rich and can afford a turbocharged H23/vtec frankenstine swap. You take the H23 bottom end, and the H22 vtec head, and I would lower compression to run a lot of boost, I don't know a lot of Honda specs so you will need to research piston sizes, valve clearance, etc. That would give you the most power potential, and go in with a lot of work, but doable...
    If you want to be realistic and keep it enjoyable to drive on public roads I think a built B18A with a cable tranny will be the easiest into the car, in fact my buddy just did one and it took a day, and they respond to turbocharging fairly well.
    -Matt
    Project CX is about to have vtec motivation
  10. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    h22 for drag only, then on a streetable car, id put a b18c5 in there and build that.
