jeffsciv23
i have a d16y8 with a t25 @12psi and i want more. what size T3 would best fit my engine.
Originally posted by reckedracing@Apr 12 2004, 11:08 AM
yea, that sounds like its decent sized.
i don't know trim ratios that well...
did you consider t3/t4?
and what car is this on?
i would be interested in buying your old turbo parts that you take off...
so if you wanna sell hit me up on a PM in case i don't see you reply post on here.
Originally posted by saturn_boy96@Apr 12 2004, 01:53 PM
have you had that thing on a dyno? what kind of numbers are you putting down.
and not to bad mouth hondaswap, but have you been to turbod16? they may have more info for you there.
what kind of t25 is it? is it from a dsm, or is it a true t25?
Originally posted by saturn_boy96@Apr 13 2004, 12:07 PM
turbod16 i was talking about is turbod16.com.
and the t25's off dsm's are much smaller than t25's off 240's or silvia's.
if your just after more top end hp get a t28, you can keep your manifold and exhaust you'll just be upgrading the turbo. you should be able to run up to 20 psi and that should pretty much max out your d-series.
