what is this and do i need them for my swap? would i be better off just geting a newer IM? thanks Sean
it looks like a obd 0 b18, all you need to worry about with vacuum lines is that the map, purge solenoid (depending on the ecu), and the fuel pressure regulator are plugged in, just cap everything else off
