What To Look For In P30?
What should I look for in the P30 to see if its 5spd? I know that its in the last digits. And if it will fit my b16a 95?
The last 3 will be....
North American model
(Letter)(Number)(Number)
The letter can be A, C or L
The first number will be either 0 or 5. 0=manual; 5=automatic
The last number is the firmware revision. 0, 1 or 2
Other than North America model
The letter can be J, G or E
The last number is the firmware revision. 0, 1, 2, 3 or 4
OR
(Number)(Number)(Number)
The first number will be either 0 or 9. 0=manual; 9=automatic
The second number will usually be a 0
The third number is the firmware revision. 0 or 1 will be here.
Examples:
USDM P30 manual transmission - 37820-P30-A02
USDM P30 auto transmission - 37820-P30-A51
EURO P30 (shortbox) manual transmission - 37820-P30-G00
JDM P30 (shortbox) auto transmission - 37820-P30-901
HTH
is there a jdm p30 5 spd ecu? What are the numbers to that one? will the 99-00 SI work on my 95 SiR2? Ill be using 95 EX engine harness.
Yes there is a JDM 5speed P30.
Don't know the numbers.
The plugs are different on the ECU side between OBD I and OBD II( B ).
