What type of fuel system does a D17A2 have: returnless or return?
Discussion in 'General Tech and Maintenance' started by rcaca0, Feb 5, 2014.
  1. rcaca0
    rcaca0 New Member
    Hello,
    I am in the process of a K series swap and I and doing a little bit of research. I noticed a few articles saying that the k series engine is a return less fuel system. What does that mean? What type do I have in my 2002 Civic Ex D17A2 motor? Looking at the manual for K series motor, it looks as if there are two lines going to the motor: a fuel feed line and a fuel vapor line. I am just planning on matching these lines in the swap, is there anything else I need to do?
    Thanks again,
    R
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    The fuel pressure regulator is located in the fuel pump assembly in that car...so there's not a return line.
    Best K-series swap article for that car that I've found:
    http://www.xproductionz.com/k20swap/k20swap.html
  3. rcaca0
    rcaca0 New Member
    Just wondering, so my 2002 civic is a return less fuel system? Is this right?
  4. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Seems that way. I would look at the fuel rail. If there is only one gas line going into it, it's return-less. If it has two lines, it has a return to the tank.
  5. civicious
    Houston, TX
    For all intents and purposes in this discussion, it is returnless.
