Whats another TPS Sensor that fits ZC DOHC?
Discussion in 'HYBRID -> ED-EF / DA' started by cheese9988, Feb 23, 2004.
  1. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    Anybody know what tps sensor from another engine will fit up with the ZC engine? I went to wire it up the other day, and well, the pins are broke off of it.
  2. cheese9988
    Lowell, MA
    will a sensor from a `91 dx sohc fit?
  3. Drenni
    Drenni Senior Member
    It depends I guess is the DX a MPFI or a DPFI???? If it's DPFI I'm not sure then if it will fit but the other one should fit. Hope this helps I think I have one in the garage from a old ZC engine let me know???
    later
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    Any tps mpfi tps of the same generation should work.
  5. cheese9988
    Lowell, MA
    Yep the old motor is a dpfi, that one worked fine, think that will work?
  6. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    any MPFI TPS will work, period. I run a OBD2 TPS on my OBD0 CRX currently.
    You might want to just get a new throttlebody with TPS... Easy enough to do.
    If you end up replacing the TPS alone, make sure you adjust it right. 4.5v @ WOT, 0.5v @idle.
  7. sleepn_accord
    sleepn_accord Senior Member
    just go to a honda motorcycle dealer and buy a cbr600 TPS.. they're only $35.
    it's the same thing.
  8. crx
    crx Senior Member
    cali near sac
    thats good info
  9. HondaMoCo
    HondaMoCo Senior Member
    lancaster/palmdale So Cal
    the DPFI tps will not work, it reads backwards, any tps from any MPFI honda motor will work.
  10. mikesphat
    mikesphat Senior Member
    just reverse the two outer wires on the dpfi one and it will read correctly
