whats best
Discussion in 'Engine Building' started by ND1748, Mar 25, 2004.
  1. ND1748
    ND1748 Junior Member
    i was wonderin what set up is better a b18b and b16 head, b18c and b16 head or just a stright b18c, i'm puttin it into a 93 hatch
  2. brian11to1
    brian11to1 Senior Member
    Well, how much cash you wanting to lay down, what are your goals? Then you can go from there.
  3. TechChris
    TechChris Member
    LS/Vtec or CR/Vtec would give you the most bang for your buck. That would be either a B18 or B20 block with a B16 or B18C head. You put a CR/Vtec in your car with just CAI, header and exhaust. You will end up with a very quick car for less than a GSR will cost. You will also end up with more hp and torque than a GSR. Good luck.
  4. brc80
    brc80 Senior Member
    Southern California
    Cr/Lsvtec is only cheaper if you have the block to start with.
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I would stick with the GSR longblock
  6. TechChris
    TechChris Member
    Go to importreview.com they have a bunch of dynos of different engine setups. That will give you an idea of what hp you can get from different motors. Then it is all a matter of how much money you want to spend.
  7. ND1748
    money really isn't a big problem i would say nothin over 4500 though, thanx so far
  8. uptowng2ic
    uptowng2ic Member
    NY
    If money is no problem get an Integra type that would be my first choice if you are on a budget get the GSR.
