whats faster?
Discussion in 'General Tech and Maintenance' started by 94hatchJW, Nov 4, 2008.
  1. 94hatchJW
    94hatchJW New Member
    puyallup,WA
    i just wanna know which engine would be faster out of the 2
    a bored out gsr or
    a b16 head with b20 block?
    Thanks if you can help.
  2. SlushboxTeggy
    NJ to MA to CA
    Far too many variables. What compression, what kind of bolts-on, any other internal work, even the tune can come into play. What are you looking to put this in and what are you looking to do with it? Then maybe we can answer your question of which motor to use.
  3. austin20110
    austin20110 New Member
    Northern Va
    thats a little tooo broad.
    But my quick guess is a b20 block with a b16 head
  4. psychopathic
    psychopathic New Member
    wouldnt a bored out gsr... pretty much just be a b20 with a b16 head???
  5. austin20110
    Northern Va
    pretty much
  6. 97hatch
    97hatch ?
    Anderson IN
    well without putting in pistons for the larger bore the b20/b16 will be faster because the gsr wont run
  7. austin20110
    Northern Va
    good point
  8. hunter4life
    hunter4life Rotary Man
    Canada
    This thread is pointless...too many variables as mentioned before
