Was changing rear drum and then the wheel cylinders gromet popped off, so i took out the piston thingy inside and cleaned them and put it back in the cylinder, and noticed a spring (not the ones off the brake shoes) on the ground, and was wondering if that spring was INSIDE the cylinder or part of the brake system
