wheel spacer questions
Discussion in 'Wheels / Suspension / Tires / Brakes' started by chadcharb, May 15, 2014.
  1. chadcharb
    maple valley, Wa
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
  3. TurboMirage
    hubcentric is not necessary.
    we have a writeup on the mirage board on the easy way to install non hubcentric spacers but i can't link you to it since you don't have an account. i'll PM you.
    EDIT: that won't work either.
    basically if you use the 5mm spacers with extended lugs - put the lugs in and the rotor back on make sure everything is good there. then you would put a few drops of red threadlocker between the lug holes on the spacer (after cleaning it really good of course, and you only need DROPS like if you were using a medicine dropper. put the spacer on your brake rotor aligned as best you can and put your open ended lugs on HAND TIGHT. the acorns will center the spacers on the lugs. wait a few hours and remove the lugs. if it holds, you're good! if it doesn't try again.
    here is the link with photos if you decide to register an account -
    http://www.mirageforums.net/viewtopic.php?f=4&t=53201
    btw the bolt on spacers are a better option but way too much if you are only looking for 1/4 inch.
    chadcharb likes this.
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Check out http://www.motorsport-tech.com/ , they allow you to custom spec your spacers. They made the 2" front / 3" rear adapters for the M3. Love 'em.
  5. chadcharb
    maple valley, Wa
