as most of you know, i blew my motor. i need the car in less than two weeks, so in the meantime im dropping a stock y8 back in place.
in order to do that, im taking my greddy kit off, and selling it on Ebay to help pay for the GSR swap.
in taking off the greddy kit.....a bolt stripped on the head, which was attached to the exhaust manifold. had to dremel that fucker off.....
so then i was unbolting my downpipe....yup. another nut that was soaked in wd-40 would not budge....started to strip.
decided to take the oil pan off. the bracket that held the oil pan to the flywheel cover.....yup. all 4 bolts stripped.
fuck the dremel, i went to sears and got the "stripped nut" remover. BEST 20.00 i have ever spent in a LONG time. that thing owns. all nuts came off.
so im thinking...im in the clear. nope
as i was unbolting the downpipe from the cat, the cat started to slip. i was in a compromising position under the car and could not reach my arm over to catch the cat before it fell....
CLANG.
the pics speak for themselves....
anyone know if i can just slide the wires back into the o2 sensor connector, and all will be forgiven?
CLANG.
