where do i get shielded wire?
Discussion in 'HYBRID -> ED-EF / DA' started by 88bluehf, Jun 20, 2004.
  1. 88bluehf
    88bluehf Senior Member
    Denton,TX
    in my many dpfi to mpfi conversions ive always had to use leftovers from stock harness' for the two shielded wires for the distributor....i am sick of this....i would like to know where to find shielded wire...can i order it offline? where can i get this? any help would be greatly appreciated.
  2. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    Radio Shack, other electronics stores
  3. 88bluehf
    Denton,TX
    ill have to check radio shack again last few times ive checked theyve only had really small gauged shielded wire.
  4. sleepercivic
    NC Mountains
    maybe a TV/electronics repair shop
  5. 88bluehf
    Denton,TX
    ok ...cool... i havnt thought of that ..ill have to check that out...Thanks man
  6. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    RadioShack does sell it thier cat# is 278-513. Its mic wire but will work just fine. Remember to ground the inner shield. Just go in there with the cat# on a peice of paper and ask the guy for it. Comes in 50' rolls so you have enough in case you screw up :D It is small awg, but I think that is a small signal anyway, which would explain why it is affected so much by interference.
  7. CRseX84
    CRseX84 Senior Member
    SUNY Canton College, NY.
    ya i just did this to my dizzy. and i used the shielded wire from radio shack.. ya it is small gauge, there are 2 wires withinin the shield so i just wound them together to make a biger gauge wire outa the 1. so i ran 6 or 7 diffrent shieled wires, and grounded all the shileds on the same gound... good luck
    Tyler
  8. 88bluehf
    Denton,TX
    ok cool ill check that out...
  9. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    if you run a bunch of wires togther twist them. By twisting them they are less likely to parallel other wires which should help cute down on interference.
  10. cheese9988
    Lowell, MA
    On low frequencies it does but on high frequencies it doesn't I am not sure what the signal is going from the ecu. If the signal is small enough to have interference from outside noise it is probably a low voltage signal which won't carry much current. Just use one set of wires with the shield from the distributer and you should be ok.
  11. 88bluehf
    Denton,TX
    depending on the awg of the wire i get depends on what i will do ... honda runs 14awg shielded wire for this in there stock harness ...so im gonna try to mimmick this
