where do my hoses go ??HELP
Discussion in 'HYBRID -> EG-EK / DC' started by slammedb18acivic, Mar 14, 2004.
  1. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    I have hoses from the charcoal canister that have no where to go.
    Also there is a sensor on top of my fuel rail. Are there any available diagrams out there? I would take pics but the digital is dead.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Don't you have a vacuum diagram on the underside of your hood? Dpending on what model you had before, it should be pretty accurate for most of the lines.
  3. slammedb18acivic
    pa
    i would check that but i have a carbon fiber hood. I was told that i will not use the hoses from the charcoal canister. So thats a start
  4. MarkN929RR
    MarkN929RR Member
    ummm that charcol canister contains two or 3 hoses, one goes by the intake manifold and another one runs to a map sensor, I was told that was just for emissions and another one that runs somewhere else, sorry im not to clear but hopefully that will help
  5. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    i thought you had this figured out? am I going to have come over there on saturday and 0wn your vacuum lines?
  6. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  7. slammedb18acivic
    pa
    thanks for the diagram, but my motor is obd2. We just got emissions in pa but not neccesary. I will just need to get over there and start this beast. thanks
