where to add trans fluid
Discussion in 'Accord' started by PowerAddict, Sep 21, 2007.
  1. PowerAddict
    PowerAddict New Member
    I lost my alldata info, I see a few places it looks like you can put it, but where do I add tranny fluid to the 5-speed?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Fill plug above the drain plug.
  3. PowerAddict
    where are those in relation to the transmission in the vehicle.
    I see a plug on the bottom below the axle shaft on the passneger side with a 3/8'' drive, and I see a larger plug right by the fender well with a 1/2" drive.
  4. phunky.buddha
    It should be just above the drain plug. One is usually a hex bolt, the other a square drive bolt.
