In my sig you will see a list of my current mods. I haven't had a chance to dyno and tune to run the nitrous. My eventual goal is 250-275 to the wheels with some boost (not including the juice). I'm hoping to piece together turbo parts over the next 6-8 months. I'm only looking to boost 5-8psi. Car will be daily driven and taken to the track occassionally. I have no intentions to turn the car into an all out track car, and I have no ambition to autox.
Aside from the obvious parts needed for the turbo, any suggestions on what else I could get to help out my current setup? Or perhaps something that will compliment the turbo setup?
I've seen quite a few people looking into aftermarket cams. Would I see better gains if I were to upgrade valve springs and retainers at the same time? How much higher could I safely rev to with aftermarket springs and retainers? 9k, 10k, more?
A better clutch, pressure plate, and 12lbs flywheel (too light?) would eventually come, but that's likely to be after the turbo installation.
My monthly budget for parts is $400-500. Any and all suggestions are appreciated.
