which axles do i need
Discussion in 'HYBRID -> EG-EK / DC' started by jordan, Nov 2, 2003.
  1. jordan
    jordan Senior Member
    ok i have a 94 civic coupe about to finish my swap i have a b18 and a gsr tranny. which axles do i need to finish this swap up?
  2. highperboi
    highperboi Senior Member
    Alameda, California
    any B series axles
    and if you dont have the half shaft you need that too
  3. jordan
    what is the half shaft?
  4. 92civicb18b1
    92civicb18b1 The Trisexual
    the half shaft or intermediate shaft is an axle tpye deal that locks the tranny and the left driveaxle together, without this you will not be going anywhere.
  5. highperboi
    Alameda, California
    you know how ur D series your driverside axle was hella long? well the B series are both sorta equal to make them stronger. So instead of having a long axle they have a half shaft which your axle connects to.
  6. redhatch92
    redhatch92 Member
    New Jersey
    i went with 00 si axles but any b series will work
  7. 92civicb18b1
    O I used LS axles, autozone is the shit, lifetime warranty. If you don't have like 300 hp they should hold up. I'd still reccomend GSR or Si axles though
  8. jordan
    thanks for the input. i will have to find some with a lifetime warranty. might be breaking them soon.
