Which Cams
brian11to1
For a street driven car, as in daily driver... which cams would be better...
62402 (Int/Ex 192/194 max lift 399/395), 62403 (299/299 max lift 424/413), 62405 (214/216 max lift 424/420)? All crowers. Which one is hte best for my 90 LS (B18A1 Non-VTEC) Integra
the 403's are the best street/power cams that crower makes, the 402's arent as bad on gas, but then u dont get as much power. for most applications the 403's work best unless gas is a SERIOUS issue. also, with the 403's u are required to get the titanium valve spring and retainer kit to make them work properly without wrecking anything, which is another 500 bucks ( canadian). the 402's dont need the springs and retainers but do not make gains anywhere near the 403's or 404's.
