Which Cat do I use for b16a in 93 dx civic?
Discussion in 'HYBRID -> EG-EK / DC' started by wikedeye, Jun 18, 2010.
  1. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    I have swapped a b16a into my 93 dx civic and I have some questions about the cat. Do I need to use one from an integra? The exhaust is hooked up, but it was very difficult to get it together. It seems like the header is shorter, which makes the exhaust slightly shorter. Now that it is on it seems to be vibrating against the undercarriage. I did not have this problem when the d series was in there. I have looked around trying to compare the sizes of a teg cat and a civic cat, and it seems that the teg one is a bit longer. Anyone have any experience with this problem?
  2. 99sidude
    Ohio
    This was E's answer to my first ever HS post. Worked out perfect for me on my gsr swap with stock gsr header. I imagine the b16 header is the same, and an integra cat is what you need.
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    I used the 2" civic cat for a long time but I "think" Integra cat is 2.25"
    .......but I am skeptical they are different b/c the DC (USDM) header for Integras is a 2" outlet
  4. wikedeye
    Savannah, Ga.
    Thats what I was thinking. It was just too hard to connect the civic cat.
    The length is what I am concerned with. The civic cat seemed to be too short.
  5. CAFROG
    NOR-CAL
    Ahh.....I did have to take it to a muffler shop back then. You are right....let me know if it all connects
  6. wikedeye
    Savannah, Ga.
    I does connect. I have the civic one on right now. It is just too tight off a fit and the exhaust is vibrating against the under carriage.
  7. CAFROG
    NOR-CAL
    Thats weird. Mine was short....about 6-8". I had Trust (GReddy) cat back exhaust Only difference was I'm a hatchback (if you are a coupe but it should be the same in terms of the cat placement)
  8. wikedeye
    Savannah, Ga.
    Mine was probably 1.5-2.5 in too short but fits. I just took the mid pipe off and connected it to the cat then connected it to the muffler and it fit. I have the apexi ws2 cat back. I dont know if there is a difference in length from yours. I have been looking around and I think I am going to get the magnaflow cat for a teg. It is only a few dollars more than getting one from autozone.
  9. CAFROG
    NOR-CAL
    Why? Sounds like you have nice expensive exhaust now
  10. wikedeye
    Savannah, Ga.
    Why what? Why the magnaflow? It is still a real cat (not test pipe), and it is cheaper then buying the autozone version. After I get the cat replaced it will be a very nice setup. It is quiet and deep toned.
  11. CAFROG
    NOR-CAL
    Sorry.....I got confused with your post....thought you were scrapping the WS2 exhaust. I just purchased a magnaflow 2.5" cat for my 98+ ITR header. Mine had to be CARB certified for California (almost $150 delivered with no flanges on it) but I'm pretty sure that yours can be found for cheaper (CA sucks like that lol) although it does cost more if they come with the flanges.
  12. wikedeye
    Savannah, Ga.
  13. CAFROG
    NOR-CAL
    Thats Direct Fit and is around $100 cheaper then the direct fit CARB Integra one.
    Nice
  14. wikedeye
    Savannah, Ga.
    Thats what I said. I will probably order it next week.
