Then look it up. There's an ECU list in the reference materials on this site, and the one you need is on there. I know because I just went and looked at it. I'm not going to spoon feed it to you though...
So I'm new to this. I just bought a 99 Honda civic ex 5 speed. The kid I bought it from said he did a motor swap. Well once he did that it created an idle issue. He said it was the idle air control valve, but I got that replaced and still didn't fix it. So upon research I now think it's because it's the wrong ecu. Could that be the problem?? (Ive checked vacuum lines and all other common problems for idle issues.) when the cars in neutral the idle jumps from 1000-2000rpms up and down up and down. It also bogs down at lower rpms. any information would be appreciated!!!
