Which Engine?for My Del Sol
Discussion in 'HYBRID -> EG-EK / DC' started by 93'delsol'VTec, Jan 4, 2003.
  1. 93'delsol'VTec
    93'delsol'VTec Junior Member
    I have a Honda del Sol Si 93 and I would like to put another engine on it, and I would like to know whats the best engine. On the B18 or the H22 do I need any modifications like the motor mounts?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Well the b16a1 is obd0 and your car is obd1. If you want a b16, you have to get the b16a3 or the b16sirII.
    The b18a is also a obd0 engine, if you want a cheap but good swap, get the b18b (LS) but it has no vtec but is great for boost.
    Another engine is the b18c and c5 (c5 = Type R) these engines have vtec and displacement and are great NA engines. If you want to go boost these engines are not the best because you have no power until Vtec kicks in.
    The h22 is a more indepth swap. The b series are very simple swaps, not much hassle and parts are easy to find. The H22 is a bigger and heavier engine. If you are into drag it is a good engine but it kinda screws up your handeling. The parts are alot more expensive plus you have to buy a mount kit from Hasport
    It basicly comes down to what you want out of the car. If you want an autocrosser, go with b-series. If you want basicly all out dragster, go with h22 or turbo b18b. If you want a faster car for the street, go with b-series. If you want handling and fast sraightling, go with the b18b or b18c
  3. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    well your name is del sol VTEc, i'm hoping that's not the model of your car you already don't have a b16 in there already and are wanting to swap it out, i know it's a torqeless motor, but i'd save your money that you woulda swapped and work that thing, either way regaurdless......
    bseries swap = you don't need mounts,but you can get them
    h22 = need them for sure
    http://www.hasport.com/Products/Mounts.htm
  4. asmallsol
    Dude, you got to know your honda's, 93 all they made was the s and si. Si had a vtec engine (d16z6 with crappy valve cover) but it was the the b16a3.
  5. 93'delsol'VTec
    I know the engine of my car but I just want it more info about which engine will be best for my car to swap .......... THANKS.....
  6. asmallsol
    i already gave you tons of info (halfpage), what else do you want to know? What ever i missed the other guy filled you in (about the mounts)
  7. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    ALso, u cant use the B18a1 like u said. its also obd1, use the B18b 0bd1 depending on year. The b18a is cable and wont work b/c of that also.
  8. 93'delsol'VTec
  9. exhacker
    exhacker Member
    TN
    beware of the hasport mounts. i've heard they transfer a lot of the vibration to the body/frame.... so anything loose on the car will start to rattle.... fine if your car is gutted, but sucks for daily driving. just a rumor.... i have no experience in the matter.
  10. hondamidnighter
    hondamidnighter Senior Member
    I have a 93 del sol and I want to swap a b16a3. Ya'll mention that you do not need motor mounts; but what do you mean you can get them??? How about other things that you might need for a swap like ECU AND WIRING HARNESS. DO YOU NEED THAT ??????
  11. Hart-n-Sol
    Hart-n-Sol Junior Member
    yes u need mounts. 93 sol's only came with d-series motors. 94-97 came with the b16a3. u can buy the mounts from honda or get aftermarket ones. u will also need the del sol shift linkage from the 94+ model (dohc). and if u are going to go b16a3 then u can also use the factory ecu (p30). if u swap an obd2 b-series into it then u will have to covert your car to obd2 or chip your ecu and grab an obd1 dist. im swapping in a 01 usdm b18c5. it all plugs in but im not using the knock sensor.
  12. Del Slw
    Del Slw Member
    Cincinnati, OH
    you can use a b18a1, the 92-93 tegs were obd1.
    and as for the swap, you need all the motor mounts for a 94-00 teg, or 94-97 del sol vtec. and the shift linkage for the 94-97 del sol vtec. you need the wiring harness that comes with the engine. and if you go wit the b16, you only have to run the knock sensor wire, all del sol's came pre wired for vtec, with the exception of the knock sensor
  13. E_SolSi
    the B18A1 also came with a cable actuated tranny that is not compatible with the del sol's hydraulic setup (this makes it a poor choice IMO)
    mounts - yes
    shift linkage - yes
    wiring harness - not necessarily... if its JDM it wont fit your car.. your harness can be modified to work (use plugs from the JDM harness) if its USDM then it will work fine
    knock sensor - again not necissarily... if you are running a chipped P28 it wont look for one
  14. E_SolSi
    you do not need to convert your car to OBD-2 or use OBD-1 anything (distributer, injectors, alternator, anything else)
    if you are using a USDM engine and harness then just plug it all in at the shock towers
    use a chipped OBD-1 P28 and your done
    if the engine / harness is JDM then switch out the OBD-2 plugs from the JDM harness for the OBD-1 ones on your harness:
    distributer --- your OBD-1 harness has 2 plugs for the dist... the OBD-2 dist uses one plug... all of the wires line up in the same positions
    fuel injectors --- just match the colors (the yellow w/ black stripe are all the same common ground so it doesnt matter if you mix them up)
    alternator --- not sure how to swap this plug i just used an OBD-1 GSR alternator (check the helms manual for what wires are what and im sure this one will be just as easy as the others to swap out)
    O2 sensor --- these wires need to be lengthened (your stock one is in the front of the engine the ITR and other B series are in the rear under the engine) just pull 4 long wires out of the JDM harness and solder them in
    solder and shrink-wrap all the splices and your just as good as stock
  15. haccord141
    haccord141 Senior Member
    So Cali
    here u go do this:
    http://www.hondaswap.com/forums/index.php?...opic=23024&st=0
  16. btleier
    btleier Member
    Isn't that mostly just because they use urethane bushings, instead of the more forgiving rubber (or whatever they are) in stock mounts?
    Yeah the H22 is a more involved swap, but realistically once you do the research you feel pretty well prepared for the project. It's a nice, powerful foundation to start on.
