Which intake manidold?
civic707
I have a 92-95 honda civic and I have a gsr block with a b16 head but i don't have the intake manifold and i am thinking of buying a 99-00 SI manifold or any DEL SOL manifold from 96-97
The question is: If i use the SI manifold, will it have any problem with the wiring or problem with the obd1 p30 ecu i will use? In other words, will it just bolt on?
second question: will the 96-97 DEL SOL b16 manifold bolt on without any wiring modification, since it is obd2?
If there is any modification, please tell me what are they?
ps: I don't have any of the intake manifold sensors and i dont want to buy an aftermarket manifold because i don't have that amount of money.
i used a 99 si intake manifold on my obd2a(97 lx) set up there shouldn't be a problem but i would use the injectors from your d series or what ever you had in the car that was obd2a it works just the same they are all 240cc injectors
