Which is the best single cam?????
Discussion in 'Engine Building' started by rlmotors, Jan 10, 2007.
  1. rlmotors
    rlmotors Junior Member
    Which engine would be good to run if you had to run strictly stock engine, and also what motor would be good if you could work on it a little but it has to be disguised. (For example: the MINI ME) I have a rule book to follow thats why my question is so odd. Also, I can not run any forced induction or turbo..
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    f22 or d15b
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    mini me works good and runa good bump stick
  4. get_nick
    Washington State
    I think this is the 3rd or 4th thread about this "unusual" racing league.
  5. sprayit500
    sprayit500 New Member
    it sounds like he is running a dirt track 4 cylinder stock class to me..but im probably wrong.
  6. AHHVTEC
    Alabama
    yea thats what i was thinking also if thats the case go with the f22
  7. sprayit500
    where im at my customer is building a tempo and he said they checking vins to make sure that was the original engine in the car. but this guys rules could be different
  8. rlmotors
  9. 801CRX
    801CRX Got Rice?
    UTAH
    What I can make of the rules is that everything is to remain stock.
    Dont cheat be honest and a good sport.
  10. rlmotors
    Well i have a 96 integra know so I have to do something!!!! So which way should I go
  11. 801CRX
    801CRX Got Rice?
    UTAH
    Ahhh I see, So your stock engine is a DOHC (twin cam).
    Go f22 as stated by ahhvtec.
    I dont think the D15B has enough power, as in power:wieght ratio.
  12. hcivic.com
    sound like you cant run your car?
  13. rlmotors
    I can put a SOHC honda engine in it. What exactly is the F22?? I know what the F23a1 is so what is the diffrence?
  14. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Basically the same thing. A NA 2.2 litre motor. 125hp and 140tq I believe.
  15. rlmotors
    There going to let me change motors to the SOHC but it is suppose to be stock. I am sure there is going to to be some rule bending. I really cant decide between the mini-me or f23a or the older SI SOHC. Sorry I do not know my engine codes that well. I will probably be doing most of the work my self. With the help of my brother!! For example switching pistons and rods between the stock d series motors, and so forth on the F23a or any other SOHC. It is my choice. Just dont know what to run!!! Where are you from Blanco??
  16. rlmotors
    What is the diffrence in the f23a and the f22 which one has more power? Send me your email and I will send you some pics of my car it is in the process of being built. Also what axles will work in the accorrd motor and will a prelude 5 speed tranny work? What computer would you run with the accord motor the p28 or the stock accord computer? Thanks
  17. rlmotors
    Do you know how much I could cut the head?
  18. rlmotors
    If I wanted to destroke it would a crank work out of a H22?
  19. get_nick
    Washington State
    do you really think you are going to do all of this work. i hate to be pessimistic, but 90% of threads online never get done.
    it would be cheaper to buy a neon and race that. you could find one for $2000 if you shop around and not wreck your integra.
  20. Exodus
    Exodus Junior Member
    Dayton, OH
