Which o2 sensor is which? b16sir into ef/si
Discussion in 'ECU's, Electronics, and Tuning' started by freak86, Aug 9, 2006.
  1. freak86
    freak86 New Member
    Southwest Michigan
    In the middle of a swap, and I took the two o2 sensors off because I didn't want them to get damaged as I was putting the manifold/downpipe back onto the engine. Now, I can't remember which one goes into 1&4, and which one goes into 2&3. You would think it wouldn't matter, but each one goes to a different pin on the pr3 ecu, so I would think the ecu knows which one should be on 1&4 and which one should be on 2&3. It does matter which one goes where, does it not?
  2. pissedoffsol
    yes it matters.
    pin c8 goes to o2 B
    pin c16 foes to o2 A
  3. freak86
    freak86 New Member
    Southwest Michigan
    That pic is exactly what I needed, thanks.
  4. jordo155
    jordo155 Junior Member
    which pinout on a p30 ecu is for a second o2 sensor? i have to run one but i dont know which pinout to run it to
  5. pissedoffsol
    p30 requres a single 4-wire, not 2- single wire o2 sensors.
    wrong obd y0.
  6. jordo155
    then why is it puttin out a code 2?
  7. eg6sir
    :werd: one one O2 on a p30 yo..
  8. pissedoffsol
    don't know, but you should start your own thread :mellow:
