Which Size Injectors??
Discussion in 'Engine Building' started by SolLess16, Mar 28, 2004.
  1. SolLess16
    SolLess16 Senior Member
    hey i was wondering what size injectors i should run with my setup, everything is listed below in my sig, im going to run 6pds now and soon ill move up to the 8pd pulley. also will a vafc 2 be good enough to controll 450cc's ?? thanks guys any help is apeciated
  2. HellBentHONDA
    HellBentHONDA Senior Member
    wa state
    Injector size in lbs/Hr = Expected HP x BSFC / # of injectors
    use .55 for BSFC(BrakeSpecificFuelConsumption)
    To convert Inj.'s to CC's=[(Inj size in lb/Hrx454)/60]/.75
  3. SolLess16
    hey thanks for the fomula , but i dont know my estimated HP , im comming down to 360cc 450cc or venom injectors , thanks , also will a vafc2 be good to tune them?? thanks
  4. HellBentHONDA
    wa state
    how much HP do you realistically want with this setup? plug that # in to 'Exp'd HP' and as long as the injectors are a little big its ok just dont be short. be sure to convert to cc's.
    sorry dont know about VAFC.
  5. SolLess16
    hey thanks for the info , anyone know about the VAFC?? thanks
