Hey Everyone, this question is about a 1990 Eagle Talon AWD - But i think some of you can help because a lot of us boost.
I just got my Talon on the road from a 2 year slow build and i am only having one issue with it. The car smokes under boost. I had it at 10 pounds of boost and it wasn't so bad, but i up'ed it to 25 pounds of boost and it smokes quite badly. If i am light on the throttle it will not smoke and it does not smoke at all out of boost. The car has....
1- New everything on the bottom end
2- Brand new Precision SCM61
3- New Everything on the head (Valve guides, seals, etc...)
4- Metal Cometic Head Gasket.
Basically everything is new...
Now i have read, but cant remember where, that a lot of people have issues with pushing coolant into the chambers with high boost, when using a metal head gasket. Some had the problem fixed when they torqued the head to 100+ Ft. Pounds. ( I believe it was 115?? Can someone confirm?)
Any way can someone offer me some help and/or remedies they have seen work?? Thank you so much guys, otherwise the car runs great.
CLIFF NOTES:
1) Car smokes under boost only
2) New everything - Engine, turbo, seals, etc....
3) Can anyone help with some fix ideas??
Thank you Everyone!!
CLIFF NOTES:
