will a 96 y7 dizzy fit on a 00 y8 head?
97hatchdx
will the distributor from my 97 dx y7 work on the 00 ex motor im putting in?
well your beliefs were wrong, i just found out a any 92-00 dizzys are interchangeable except the z6 b7.. i think b7...and someother one.
yes because if you do a mini me swap you are required to change the dizzy
it never says that on any of the write ups. it always says unbolt the dizzy and move it aside....never says not to use the y8
No. It won't mount properly.
We've been over this many times. Yes, it will mount, but you'll be missing a mount-point, as only two bolts will fit. If you get creative with it, you can make a mount yourself, but I'd suggest just buying the right part.
<shameless plug>
I've got a y8 distributor for sale. Check the FS thread in my sig.
</shameless plug>
your car will misfire like crazy because it wont mount in all the way.....i did it before to my y8
