Will it fit?
22crazy
just curious...will h22 connecting rods fit a b20 crank...if not is it possible to make it fit? Is there any other clearance issues that someone would have to consider? thanks.
what do u mean length? I wanted the h22 rods cause they are longer, but i was wondering if the bearing on the rod with fit the individual shaft (there are 4 of them, i dont know the proper name but its where the connecting rods connect on the crankshaft) properly fits. Those are the clearance issues im talking about. If im not being clear about what im describing, ill try to draw a pic after.
an h22 rod won't fit onto a b20 or b-anything crank.
let alone the stroke difference...
