will p30 run swapped d15b?
Discussion in 'HYBRID -> ED-EF / DA' started by HATCHET_HONDA, May 21, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    i have a d15b swapped in my 90 si hatch...im also doin a b16 into a dx i have. im having ecu problems with the p28 im using for the d15.. can i use the jdm p30 i have to run the d15b and see if the ecu is bad?
  2. eg6sir
    it'll run.. but not very good
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    :werd: It shouldn't be too bad though. I was using a F22A1(PT3) ECU on my D15B; it started but was running very rich.
