will these axles work with my swap?
Discussion in 'Civic and CRX - EF' started by 88SuperSi, Apr 30, 2010.
  1. 88SuperSi
    88SuperSi New Member
    hey guys im getting ready to drop my brothers b16a2 engine and trans in my 88 [COLOR=#0072bc! important][COLOR=#0072bc! important]crx[/COLOR][/COLOR] si, my question is i know the b16a2 crank angle sensor is located at the oil pump and not the dizzy, im doing a obd1 conversion with this swap, am i going to need an obd 1 dizzy to make it work correctly? thanks.
  2. 88SuperSi
    Sorry some how i screwed up my post, this was the actual post i meant to put thanks.
    hey guys im putting a b16a2 engine and transmission out of a 99-00 Si in my 88 crx Si, ive heard alot of mixed answers on this but i need a 100% straight up answer, i have a complete set of 92-95 b16 eg axles with the intermidiate shaft, will these work with my swap? thanks guys.
  3. 88SuperSi
    im sure someone got to know this?
  4. civichatch1988
    civichatch1988 Ef hatch
    Seattle
    if the axles are for the motor? the b16 axles then yes they will fit your EF as long as the car has 5 speed hubs and not 4 speed or HF hubs
