Will this work?
dreded90crxsi
I'm gonna be doing a mini me swap on my crx in a couple weeks (waiting for the parts) and I'm going with the obd0-obd1 swap using a p28 ecu. I know I will have to do some changes to the wiring, my question is if the obd1 oxygen sensor will fit in my current stock header (d16a6) or will I need a z6 header? Sorry if this is the wrong section for this post.
you may need to extend the wires, but it physically will screw in there from my experience. i dont recall the exact location of the O2 sensor on the d16a6... been so long since i've worked on a d series :)
It will fit, but the location is not in the correct OBD1 location. It should be down near the cat on the OBD1 setup.
Jason
