Windsheild Sprayers
Discussion in 'General Tech and Maintenance' started by GSRCRXsi, Jan 6, 2003.
  1. GSRCRXsi
    MD
    ok my windsheild sprayers arent working. have no idea what could be wrong. i pull the little bar thing on my sterring collum to spray them but nothing comes out. any suggestions?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    when i first say this one i thought of those gay neon things. Anyways, have a freind pull the lever and you put your ear near the engine (resevroir) if you can hear the pump going then your ok with that, you probally have a clug somewhere, If you dont here it, then your pump is burned out or your fuse is blown.
  3. E_SolSi
    theres fluid in the tank right?? ;)
    ummm
    is the pump making noise (you should hear a humming sound)-----{replace the pump}
    if so check for a broken line (look for fluid spilling out somewhere)-----{replace the line}
    lines could be frozen (if your in a cold area right now)-----{let the car warm up for a while it should thaw then add some washer fluid anti-freeze stuff}
    could be clogged (unlikely)-----{probly have to replace the line}
  4. GSRCRXsi
    MD
    ok i havent checked yet, but if it is the pump, how much is it, and where is it located on the car (91 CRX) and is it hard to replace or should i not bother and have someone else do it?
  5. Prowler
    Prowler Super Moderator
    B MT
    Just pull the little hoses off under the nozzles and see if anything comes through. Mine had rusted out, so I did buy the ghey Eurolite washers as replacements. And NO they're not on. They flow much better than the stock nozzles.
  6. paragus
    paragus Senior Member
    lol@they flow better
  7. asmallsol
    yea i kinda laughed at that too.
  8. cxjon
    cxjon Senior Member
    man+k+toe
    they flow better and add hp!
  9. paragus
    really?? wow! im getting some
  10. sportlinecrx
    sportlinecrx Banned
    its true! they flow like a guy who just drank a six pack!
  11. cxjon
    cxjon Senior Member
    man+k+toe
  12. asmallsol
    do they mist or do they just do a squirt gun stream kind of thing. My stock ones just do the thin stream and it bugs the hell out of me, but one plus is when i aim them upwards, i can clear my rear bumper while driving, nothing better to use when people are tailing you.
  13. Prowler
    B MT
    It hoses at my windshield. Gets the windows nice and clean. I just need to paint the gay things black.
  14. initialauto
    initialauto Member
    Los Angeles CA
    my friend gave me one of those neon things for my bday. looks a lot better then the stock ones. it's silver in color. matches my car. but that shit looks gay when its turned on. i seen a car with it on 2day. that car looked like a UFO.
