Wipers don't work
Discussion in 'General Tech and Maintenance' started by sleepn_accord, Aug 18, 2005.
  1. sleepn_accord
    sleepn_accord Senior Member
    debated if this should go in electronics..but I don't know.
    99 Integra.
    I've checked almost everything possible.
    Changed the motor. nope
    Changed the integrated control unit. nope
    changed the switch. nope
    help would be appreciated.
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Did you check the fuse? :unsure:
  3. sleepn_accord
    Found the problem.
    The switch was bad..but the problem caused the switch to appear to be good based on continuity tests.. :blink:
