hcivic.com
ok i pmd and asked about another vehicle here is the list i have if a mod could make a sticky i don't rember where i got it from
BMW
P o w e r
Memory (+12v Constant) Gray/Red
Ignition (+12v Switched) Violet
Ground (-) Brown
Illumination White/Blue
Dimmer (none)
Power Antenna White
S p e a k e r s
Right Front (+) Gray/White
Right Front (-) Gray/Brown
Left Front (+) Gray/Red
Left Front (-) Gray/Violet
Right Rear (+) Black/White
Right Rear (-) Black/Brown
Left Rear (+) Black/Red
Left Rear (-) Black/Violet
DODGE/CHRYSLER
P o w e r
Memory (+12v Constant) Red/White
Ignition (+12v Switched) Red
Ground (-) Black or Braided Silver Wire
Illumination Orange
Dimmer (none)
Power Antenna Yellow
S p e a k e r s
Right Front (+) Violet
Right Front (-) Blue/Red
Left Front (+) Green
Left Front (-) Brown/Red
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Red
FORD
P o w e r
Memory (+12v Constant) Green Yellow
Ignition (+12v Switched) Yellow/Black
Ground (-) Black or Fat Red
Illumination Orange
Dimmer Orange/White
Power Antenna Blue (varies greatly)
S p e a k e r s
Right Front (+) White/Green
Right Front (-) Green/Orange
Left Front (+) Orange/Green
Left Front (-) Light Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/orange
Left Rear (+) Pink/green
Left Rear (-) Pink/Blue
GENERAL MOTORS
P o w e r
Memory (+12v Constant) Orange
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Dark Green
Left Front (+) Tan
Left Front (-) Gray
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Left Rear (+) Brown
Left Rear (-) Yellow
HONDA/ACURA
P o w e r
Memory (+12v Constant) Blue/White
Ignition (+12v Switched) Yellow/Red
Ground (-) Black
Illumination Red/Black
Dimmer (none)
Power Antenna Yellow/White
S p e a k e r s
Right Front (+) Red/Green
Right Front (-) Brown/Black
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
ISUZU
P o w e r
Ignition (+12v Switched) Orange
Ground (-) Black/Yellow
Illumination Green/Red
Dimmer Red/Green
Power Antenna (none)
S p e a k e r s
Right Front (-) Gray/Green
Left Front (+) Yellow
Left Front (-) Blue/Yellow
Right Rear (+) White
Right Rear (-) Red/White
Left Rear (+) Orange
Left Rear (-) Black/Orange
JEEP
P o w e r
Memory (+12v Constant) Pink
Ignition (+12v Switched) Violet/White
Ground (-) Black
Illumination Orange
Dimmer Blue/White
Power Antenna
S p e a k e r s
Right Front (-) Black
Left Front (-) Black/Yellow
Right Rear (+) White/Black
Left Rear (+) Green/White
Left Rear (-) Brown/White
MAZDA
P o w e r
Memory (+12v Constant) Blue/Red
Ignition (+12v Switched) Blue/White
Ground (-) Black
Dimmer (none)
Power Antenna Blue (some have a (-) trigger, need relay)
S p e a k e r s
Right Front (+) Blue/Red
Right Front (-) Blue/Orange
Left Front (+) Blue
Left Front (-) Blue/White
Right Rear (+) Blue/Orange
Right Rear (-) Blue/Black
Left Rear (+) Blue/White
Left Rear (-) Blue/Green
MERCEDES BENZ
P o w e r
Ignition (+12v Switched) Black/Yellow
Ground (-) Brown
Illumination Gray/Blue
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Right Front (+) Black/Green
Left Front (+) Black/Red
Right Rear (+) Black/Green
Left Rear (-) Black
MITSUBISHI
P o w e r
Memory (+12v Constant) Red/White or White/Green
Ground Most don't have one Black
Illumination Green/White
Dimmer Black/White or Black/Yellow
Power Antenna White/Black
S p e a k e r s
Right Front (+) White/Red
Right Front (-) Black/Red
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Left Rear (+) Yellow/Red
Left Rear (-) Gray/Blue
NISSAN
P o w e r
Ignition (+12v Switched) (varies) Brown or Green
Ground (-) Black (varies - most don't have one)
Illumination Red/White
Dimmer Red/Black
Power Antenna Green
S p e a k e r s
Right Front (+) Brown
Right Front (-) Brown/White
Left Front (-) Black/White
Right Rear (+) Blue
Right Rear (-) Pink
Left Rear (+) Red
Left Rear (-) Green
SAAB
P o w e r
Ground (-) Black
Illumination Brown/White
Dimmer (none)
Power Antenna Green
S p e a k e r s
Right Front (-) Red
Right Rear (+) White/Blue
Right Rear (-) White/Red
Left Rear (+) White/Green
Left Rear (-) White/Brown
SUBARU
P o w e r
Memory (+12v Constant) Red/Green
Ignition (+12v Switched) Blue/Yellow
Ground (-) Black
Illumination
Dimmer
Power Antenna Red/White
S p e a k e r s
Right Front (-) Blue/Black
Left Front (-) Blue/Red
Left Rear (+) Yellow/White
Left Rear (-) Blue/Red
TOYOTA
P o w e r
Memory (+12v Constant) Blue/Yellow
Ignition (+12v Switched) Gray
Ground (-) Brown
Illumination Green
Dimmer White/Green
Power Antenna Black/Red
S p e a k e r s
Left Front (+) Pink
Left Front (-) Violet
Right Rear (+) Red
Left Rear (+) Black
VOLVO
P o w e r
Ground (-) Fat Black
Illumination Yellow (not on plug)
Dimmer (none)
Power Antenna Red
S p e a k e r s
Left Front (+) Blue/Yellow
Left Front (-) White
Right Rear (+) Green/Brown
Left Rear (+) Yellow/Brown
Left Rear (-) Yellow/Green
VOLKSWAGEN
P o w e r
Ignition (+12v Switched) Black (not available in older models)
Ground (-) Brown
Illumination Gray or Gray/Blue
Dimmer (none)
Power Antenna White
S p e a k e r s
Right Front (+) Red
Left Front (+) Blue
Left Front (-) Brown/Blue
Right Rear (+) Red/Green
Right Rear (-) Brown/Black
Left Rear (+) Blue/Green
PIONEER
P o w e r
Ground (-) Black
Illumination Yellow
Phone Mute Yellow/Black
Power Antenna Blue
S p e a k e r s
Right Front (-) Gray/Black
Left Front (-) Green/Black
Right Rear (+) Gray/Red
Right Rear (-) Black/Gray
Left Rear (+) Green/Red
Left Rear (-) Black/Green
SONY, ALPINE
P o w e r
Memory (+12v Constant) Yellow
Ground (-) Black
Dimmer Pink/White (Alpine only)
Power Antenna Blue
Amplifier Turn-on Blue/White
S p e a k e r s
Left Front (-) White/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Left Rear (+) Green
Left Rear (-) Green/Black
there are some hole under subs if you know them let me know so i can fill it in
BMW
P o w e r
Ground (-) Brown
Dimmer (none)
Power Antenna White
S p e a k e r s
DODGE/CHRYSLER
P o w e r
Illumination Orange
Dimmer (none)
S p e a k e r s
FORD
P o w e r
Illumination Orange
Dimmer Orange/White
S p e a k e r s
GENERAL MOTORS
P o w e r
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
HONDA/ACURA
P o w e r
Ground (-) Black
Dimmer (none)
S p e a k e r s
ISUZU
P o w e r
Dimmer Red/Green
S p e a k e r s
JEEP
P o w e r
Ground (-) Black
Illumination Orange
Dimmer Blue/White
Power Antenna
S p e a k e r s
MAZDA
P o w e r
Ground (-) Black
Dimmer (none)
S p e a k e r s
Left Front (+) Blue
MERCEDES BENZ
P o w e r
Ground (-) Brown
Dimmer (none)
Power Antenna Blue
S p e a k e r s
Left Rear (-) Black
MITSUBISHI
P o w e r
S p e a k e r s
NISSAN
P o w e r
Dimmer Red/Black
Power Antenna Green
S p e a k e r s
Right Rear (+) Blue
Right Rear (-) Pink
Left Rear (+) Red
Left Rear (-) Green
SAAB
P o w e r
Ground (-) Black
Dimmer (none)
Power Antenna Green
S p e a k e r s
Right Front (-) Red
SUBARU
P o w e r
Ground (-) Black
Illumination
Dimmer
S p e a k e r s
TOYOTA
P o w e r
Ground (-) Brown
Illumination Green
Dimmer White/Green
S p e a k e r s
Left Front (+) Pink
Right Rear (+) Red
Left Rear (+) Black
VOLVO
P o w e r
Dimmer (none)
Power Antenna Red
S p e a k e r s
VOLKSWAGEN
P o w e r
Ground (-) Brown
Dimmer (none)
Power Antenna White
S p e a k e r s
Right Front (+) Red
Left Front (+) Blue
PIONEER
P o w e r
Ground (-) Black
Illumination Yellow
Power Antenna Blue
S p e a k e r s
SONY, ALPINE
P o w e r
Ground (-) Black
Power Antenna Blue
S p e a k e r s
Left Rear (+) Green
