Wiring A B18c Gsr Into A 99 Civic Ex
nash
do i have to rewire the whole car?which ecu should i be using?
thanks
replying to your pm:
if it is obd2 you dont have to worry about rewiring teh ENTIRE car. just get the gsr OBD2 ecu to match ( i forget the code) then you will have to wire up the IAB's. do a serch of read the article section on that its #51
