Wiring harness question, jdm h22a obd2 into 01 prelude HELP!
Discussion in 'Prelude' started by preludeNewbie, Jun 8, 2007.
  1. preludeNewbie
    preludeNewbie New Member
    Hi,
    I am putting a 97+ JDM H22a with obd2 into a USDM 01 prelude to replace the blew out H22a4. The jdm engine came with cut wiring harness and the shop that is doing the work couldn't figure how to connect the wiring harness. Appreciate any help with regards to what wiring harness to get.
    thanks
  2. japish
    japish Junior Member
    your suppost to use your stock wiring harness and modify it for the jdm motor, make sure to use a jdm ecu and a ff-squad disabler delete on your swap
