wiring hrness extra clips
Discussion in 'General Tech and Maintenance' started by INJEN78, Feb 14, 2008.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok i just pulled the harness from my old engine and i started hooking it up to the new engine,,the problem is i have 2 clips left,,one down under the intake manifold and one down by the tranny...i also have a (green)sensor in the back of the block down towards the oil pan..is it normal to have left over clips/sensors??\
    neither off the clips hook to the sensor though
    wiring harness is for/off a d16a6
    and its going on a b18a1
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the connector under the manifold is probably for the Fast Idle Control Valve on the Si - 2-wire connector with blue and black/yellow wires - the B18 doesn't have FICV like the Si - just leave it - what color are the wires at the one by the transmission? could be the back-up light switch? back-up light switch has 2 wires, yellow and green/black with bullet connectors - switch is on top of the D-series transmission and is on the bottom end on the B-series - the green sensor on the back of the B18 block is oil temperature sensor - you don't need it
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok so the one under the im is for fitv,,,just remebred when you said something..and what will happen if i dont plug in the oil temp switch???
    there are 2 bullet connectors by the tranny but there is also another sensor..ill try to get a pic
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    what the hell is this?!?!it is right nect to the fuel rail on the motor...has a 3 wire clip on it
      File size:
      18.6 KB
      199
      File size:
      14.8 KB
      176
      File size:
      16.7 KB
      160
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    still wondering what that thing is
  7. honda91efhatch
    honda91efhatch 91 ef/dx project
    charleston, sc
    looks like a plug for the dizzy?!?!?
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    def. not...there are 2 dizzy plugs,and the thing pictured is the egr valve
  9. mattintegra
    mattintegra New Member
    Seneca, Sc
    Same problem
    I have the same problem. Cant figure out where they would connect to. Also have a problem with my b18a1. It starts after some spitting and sputtering. It idles fine at 1000 rpms. At around 3000 it starts sounding like its hitting the rev limiter. Anyone have any ideas what this could be? Could it be my EGR valve is bad?
  10. DESPAIN
    flower mound TX
    soundsd like a bad dizzy. You are in limp mode.
  11. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    yo injen... i cant find the old valve covers thread... could ya help me out man? i just finished mine and it looks super sweet, but dont... well i just said it so, pm if you can help!
    and wtf? i didnt know you were doin' a B series swap?! shit, very nice...
