wiring question
mord
OK so im doing the wiring before i drop the 1998 b18c1 in my car a 95 civic ex I ran the knock sensor wire all that's left is the IAP sensor secondary intake solenoid if im not mistaken its the one hidden under the intake manifold with the small canister on it im not totally sure and I cant locate the wire for it on the engine side plugs I added a wire running from the ECU but where does it connect? any ideas
I am having the same problem. wiring my OBDI gsr into my obdI LS integra. I know I need to connect 7 wires, but there are only 5 blanks in my car harness. I found all the colors I need except for the vtec ground (black-- i figure it is already grounded) and the pink/blue wire.There is no pink/blue coming out the the engine harness on the passanger side, only the drivers side, but there is no pin in A17. Any ideas?
